BSOD with batchmnt.exe unmountall
WinCDEmu - Report bugs, discuss features, etc.
Postby flockster » Tue Nov 15, 2011 12:50 pm
Hi,
I updated version 3.3 to 3.6 but after that i get an BSOD with batchmnt.exe /unmountall on Bazisvirtualcd.sys.
I have got Windows 7 x86.
I uninstalled both but still i get an BSOD.
I hope u could help me.
Grtz
Floris
flockster
Re: BSOD with batchmnt.exe unmountall
Postby bazis » Thu Nov 17, 2011 11:30 am
Hi, could you please attach a minidump here? The minidumps are located in C:\windows\minidump. By analyzing the minidump I will be able to understand and fix the cause of the BSOD!
bazis
Sysprogs
Postby bazis » Thu Nov 17, 2011 2:50 pm
Thanks for the minidump. I think, I've found the problem. Please check this version: http://wincdemu.sysprogs.org/temp/BazisVirtualCDBus.sys
bazis
Sysprogs
Postby risaer_ » Wed Oct 10, 2012 5:17 pm
Hallo,
I have got the same promblems. I am running Windows 7 64-bit version. The file above you have submitted seems to have the same version number with a different file date, so I guess it is a newer version, although the last posting is quite old.
So now I have got 3 questions:
1) I assume, this could fix the problem, is this correct?
2) I have found 3 locations of this file. Could you please tell where to put it?
3) Is it possible that you include the new file into the download?
Oh, if you need the dump files: https://dl.dropbox.com/u/22253273/minidumps.zip
risaer_
Return to WinCDEmu
Who is online
Users browsing this forum: No registered users and 1 guest
