Reply To: Need help: visualgdb cannot find gdbserver even though the gdbserver exists
Sysprogs forums Forums VisualGDB Need help: visualgdb cannot find gdbserver even though the gdbserver exists Reply To: Need help: visualgdb cannot find gdbserver even though the gdbserver exists
#7762
zhongliu
Participant
Hi,
Yes, I made the change, but still cannot hit the breakpoint, I collect outputs and listed below:
************* gdbserver output *************
Attached; pid = 3735
gdbserver: Unable to determine the number of hardware watchpoints available.
gdbserver: Unable to determine the number of hardware breakpoints available.
Listening on port 5039
Remote debugging from host 127.0.0.1
************* All interaction output *************
C:\Android\android-ndk-r10e\toolchains\aarch64-linux-android-4.9\prebuilt\windows\bin\aarch64-linux-android-gdb.exe –interpreter mi “C:\Users\zl121\AppData\Local\VisualGDB\AndroidBinaryCache\9416189d\app_process64” -x “C:\Zhong\workspace\gdb_test1\gdb_test1\libs\arm64-v8a\gdb.setup”
-gdb-version
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 7.7\n”
~”Copyright (C) 2014 Free Software Foundation, Inc.\n”
~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law.  Type \”show copying\”\nand \”show warranty\” for details.\n”
~”This GDB was configured as \”–host=i586-pc-mingw32msvc –target=aarch64-elf-linux\”.\nType \”show configuration\” for configuration details.”
~”\nFor bug reporting instructions, please see:\n”
~”<http://source.android.com/source/report-bugs.html&gt;.\n”
~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
~”For help, type \”help\”.\n”
~”Type \”apropos word\” to search for commands related to \”word\”…\n”
~”Reading symbols from C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\app_process64…”
~”(no debugging symbols found)…done.\n”
=cmd-param-changed,param=”solib-search-path”,value=”./obj/local/arm64-v8a”
~”Type \”apropos word\” to search for commands related to \”word\”.\n”
^done
-list-features
^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”,”python”]
-gdb-set stop-on-solib-events 1
^done
-gdb-set disassembly-flavor intel
^error,msg=”No symbol table is loaded.  Use the \”file\” command.”
-gdb-set print demangle off
^done
-gdb-set solib-search-path C:/Users/zl121/AppData/Local/VisualGDB/AndroidBinaryCache/9416189d;C:/Zhong/workspace/gdb_test1/gdb_test1/obj/local/arm64-v8a
^done
-target-select remote :5039
=thread-group-started,id=”i1″,pid=”3735″
=thread-created,id=”1″,group-id=”i1″
=library-loaded,id=”/system/bin/linker64″,target-name=”/system/bin/linker64″,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\linker64″,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libNimsWrap.so”,target-name=”/system/vendor/lib64/libNimsWrap.so”,host-name=”/system/vendor/lib64/libNimsWrap.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcutils.so”,target-name=”/system/lib64/libcutils.so”,host-name=”/system/lib64/libcutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libutils.so”,target-name=”/system/lib64/libutils.so”,host-name=”/system/lib64/libutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/liblog.so”,target-name=”/system/lib64/liblog.so”,host-name=”/system/lib64/liblog.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbinder.so”,target-name=”/system/lib64/libbinder.so”,host-name=”/system/lib64/libbinder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid_runtime.so”,target-name=”/system/lib64/libandroid_runtime.so”,host-name=”/system/lib64/libandroid_runtime.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwilhelm.so”,target-name=”/system/lib64/libwilhelm.so”,host-name=”/system/lib64/libwilhelm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libc++.so”,target-name=”/system/lib64/libc++.so”,host-name=”/system/lib64/libc++.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libc.so”,target-name=”/system/lib64/libc.so”,host-name=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libm.so”,target-name=”/system/lib64/libm.so”,host-name=”/system/lib64/libm.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbacktrace.so”,target-name=”/system/lib64/libbacktrace.so”,host-name=”/system/lib64/libbacktrace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemtrack.so”,target-name=”/system/lib64/libmemtrack.so”,host-name=”/system/lib64/libmemtrack.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroidfw.so”,target-name=”/system/lib64/libandroidfw.so”,host-name=”/system/lib64/libandroidfw.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexpat.so”,target-name=”/system/lib64/libexpat.so”,host-name=”/system/lib64/libexpat.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativehelper.so”,target-name=”/system/lib64/libnativehelper.so”,host-name=”/system/lib64/libnativehelper.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetutils.so”,target-name=”/system/lib64/libnetutils.so”,host-name=”/system/lib64/libnetutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libui.so”,target-name=”/system/lib64/libui.so”,host-name=”/system/lib64/libui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libgui.so”,target-name=”/system/lib64/libgui.so”,host-name=”/system/lib64/libgui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinput.so”,target-name=”/system/lib64/libinput.so”,host-name=”/system/lib64/libinput.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libinputflinger.so”,target-name=”/system/lib64/libinputflinger.so”,host-name=”/system/lib64/libinputflinger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_client.so”,target-name=”/system/lib64/libcamera_client.so”,host-name=”/system/lib64/libcamera_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcamera_metadata.so”,target-name=”/system/lib64/libcamera_metadata.so”,host-name=”/system/lib64/libcamera_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libskia.so”,target-name=”/system/lib64/libskia.so”,host-name=”/system/lib64/libskia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsqlite.so”,target-name=”/system/lib64/libsqlite.so”,host-name=”/system/lib64/libsqlite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libEGL.so”,target-name=”/system/lib64/libEGL.so”,host-name=”/system/lib64/libEGL.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv1_CM.so”,target-name=”/system/lib64/libGLESv1_CM.so”,host-name=”/system/lib64/libGLESv1_CM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLESv2.so”,target-name=”/system/lib64/libGLESv2.so”,host-name=”/system/lib64/libGLESv2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libETC1.so”,target-name=”/system/lib64/libETC1.so”,host-name=”/system/lib64/libETC1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware.so”,target-name=”/system/lib64/libhardware.so”,host-name=”/system/lib64/libhardware.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhardware_legacy.so”,target-name=”/system/lib64/libhardware_legacy.so”,host-name=”/system/lib64/libhardware_legacy.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libselinux.so”,target-name=”/system/lib64/libselinux.so”,host-name=”/system/lib64/libselinux.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsonivox.so”,target-name=”/system/lib64/libsonivox.so”,host-name=”/system/lib64/libsonivox.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcrypto.so”,target-name=”/system/lib64/libcrypto.so”,host-name=”/system/lib64/libcrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libssl.so”,target-name=”/system/lib64/libssl.so”,host-name=”/system/lib64/libssl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicuuc.so”,target-name=”/system/lib64/libicuuc.so”,host-name=”/system/lib64/libicuuc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libicui18n.so”,target-name=”/system/lib64/libicui18n.so”,host-name=”/system/lib64/libicui18n.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia.so”,target-name=”/system/lib64/libmedia.so”,host-name=”/system/lib64/libmedia.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjpeg.so”,target-name=”/system/lib64/libjpeg.so”,host-name=”/system/lib64/libjpeg.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libusbhost.so”,target-name=”/system/lib64/libusbhost.so”,host-name=”/system/lib64/libusbhost.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libharfbuzz_ng.so”,target-name=”/system/lib64/libharfbuzz_ng.so”,host-name=”/system/lib64/libharfbuzz_ng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libz.so”,target-name=”/system/lib64/libz.so”,host-name=”/system/lib64/libz.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libaudioutils.so”,target-name=”/system/lib64/libaudioutils.so”,host-name=”/system/lib64/libaudioutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpdfium.so”,target-name=”/system/lib64/libpdfium.so”,host-name=”/system/lib64/libpdfium.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libimg_utils.so”,target-name=”/system/lib64/libimg_utils.so”,host-name=”/system/lib64/libimg_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnetd_client.so”,target-name=”/system/lib64/libnetd_client.so”,host-name=”/system/lib64/libnetd_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio.so”,target-name=”/system/lib64/libradio.so”,host-name=”/system/lib64/libradio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoundtrigger.so”,target-name=”/system/lib64/libsoundtrigger.so”,host-name=”/system/lib64/libsoundtrigger.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libminikin.so”,target-name=”/system/lib64/libminikin.so”,host-name=”/system/lib64/libminikin.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprocessgroup.so”,target-name=”/system/lib64/libprocessgroup.so”,host-name=”/system/lib64/libprocessgroup.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnativebridge.so”,target-name=”/system/lib64/libnativebridge.so”,host-name=”/system/lib64/libnativebridge.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libradio_metadata.so”,target-name=”/system/lib64/libradio_metadata.so”,host-name=”/system/lib64/libradio_metadata.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libhwui.so”,target-name=”/system/lib64/libhwui.so”,host-name=”/system/lib64/libhwui.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright.so”,target-name=”/system/lib64/libstagefright.so”,host-name=”/system/lib64/libstagefright.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_foundation.so”,target-name=”/system/lib64/libstagefright_foundation.so”,host-name=”/system/lib64/libstagefright_foundation.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_http_support.so”,target-name=”/system/lib64/libstagefright_http_support.so”,host-name=”/system/lib64/libstagefright_http_support.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libeffects.so”,target-name=”/system/lib64/libeffects.so”,host-name=”/system/lib64/libeffects.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbase.so”,target-name=”/system/lib64/libbase.so”,host-name=”/system/lib64/libbase.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libunwind.so”,target-name=”/system/lib64/libunwind.so”,host-name=”/system/lib64/libunwind.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstdc++.so”,target-name=”/system/lib64/libstdc++.so”,host-name=”/system/lib64/libstdc++.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsync.so”,target-name=”/system/lib64/libsync.so”,host-name=”/system/lib64/libsync.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpng.so”,target-name=”/system/lib64/libpng.so”,host-name=”/system/lib64/libpng.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libft2.so”,target-name=”/system/lib64/libft2.so”,host-name=”/system/lib64/libft2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqc-opt.so”,target-name=”/system/vendor/lib64/libqc-opt.so”,host-name=”/system/vendor/lib64/libqc-opt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libGLES_trace.so”,target-name=”/system/lib64/libGLES_trace.so”,host-name=”/system/lib64/libGLES_trace.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwpa_client.so”,target-name=”/system/lib64/libwpa_client.so”,host-name=”/system/lib64/libwpa_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpcre.so”,target-name=”/system/lib64/libpcre.so”,host-name=”/system/lib64/libpcre.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libnbaio.so”,target-name=”/system/lib64/libnbaio.so”,host-name=”/system/lib64/libnbaio.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libspeexresampler.so”,target-name=”/system/lib64/libspeexresampler.so”,host-name=”/system/lib64/libspeexresampler.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRS.so”,target-name=”/system/lib64/libRS.so”,host-name=”/system/lib64/libRS.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libRScpp.so”,target-name=”/system/lib64/libRScpp.so”,host-name=”/system/lib64/libRScpp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdrmframework.so”,target-name=”/system/lib64/libdrmframework.so”,host-name=”/system/lib64/libdrmframework.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediautils.so”,target-name=”/system/lib64/libmediautils.so”,host-name=”/system/lib64/libmediautils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libopus.so”,target-name=”/system/lib64/libopus.so”,host-name=”/system/lib64/libopus.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_omx.so”,target-name=”/system/lib64/libstagefright_omx.so”,host-name=”/system/lib64/libstagefright_omx.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_yuv.so”,target-name=”/system/lib64/libstagefright_yuv.so”,host-name=”/system/lib64/libstagefright_yuv.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libvorbisidec.so”,target-name=”/system/lib64/libvorbisidec.so”,host-name=”/system/lib64/libvorbisidec.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libpowermanager.so”,target-name=”/system/lib64/libpowermanager.so”,host-name=”/system/lib64/libpowermanager.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_enc_common.so”,target-name=”/system/lib64/libstagefright_enc_common.so”,host-name=”/system/lib64/libstagefright_enc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_avc_common.so”,target-name=”/system/lib64/libstagefright_avc_common.so”,host-name=”/system/lib64/libstagefright_avc_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libprotobuf-cpp-lite.so”,target-name=”/system/lib64/libprotobuf-cpp-lite.so”,host-name=”/system/lib64/libprotobuf-cpp-lite.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcommon_time_client.so”,target-name=”/system/lib64/libcommon_time_client.so”,host-name=”/system/lib64/libcommon_time_client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcc.so”,target-name=”/system/lib64/libbcc.so”,host-name=”/system/lib64/libbcc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libbcinfo.so”,target-name=”/system/lib64/libbcinfo.so”,host-name=”/system/lib64/libbcinfo.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libLLVM.so”,target-name=”/system/lib64/libLLVM.so”,host-name=”/system/lib64/libLLVM.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”[vdso]”,target-name=”[vdso]”,host-name=”[vdso]”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libcneconn.so”,target-name=”/system/vendor/lib64/libcneconn.so”,host-name=”/system/vendor/lib64/libcneconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libvendorconn.so”,target-name=”/system/vendor/lib64/libvendorconn.so”,host-name=”/system/vendor/lib64/libvendorconn.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libavenhancements.so”,target-name=”/system/vendor/lib64/libavenhancements.so”,host-name=”/system/vendor/lib64/libavenhancements.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_httplive.so”,target-name=”/system/lib64/libstagefright_httplive.so”,host-name=”/system/lib64/libstagefright_httplive.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmediaplayerservice.so”,target-name=”/system/lib64/libmediaplayerservice.so”,host-name=”/system/lib64/libmediaplayerservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_wfd.so”,target-name=”/system/lib64/libstagefright_wfd.so”,host-name=”/system/lib64/libstagefright_wfd.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcurl.so”,target-name=”/system/lib64/libcurl.so”,host-name=”/system/lib64/libcurl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libExtendedExtractor.so”,target-name=”/system/vendor/lib64/libExtendedExtractor.so”,host-name=”/system/vendor/lib64/libExtendedExtractor.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libdashplayer.so”,target-name=”/system/lib64/libdashplayer.so”,host-name=”/system/lib64/libdashplayer.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libart.so”,target-name=”/system/lib64/libart.so”,host-name=”/system/lib64/libart.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsigchain.so”,target-name=”/system/lib64/libsigchain.so”,host-name=”/system/lib64/libsigchain.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacore.so”,target-name=”/system/lib64/libjavacore.so”,host-name=”/system/lib64/libjavacore.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/memtrack.msm8996.so”,target-name=”/system/lib64/hw/memtrack.msm8996.so”,host-name=”/system/lib64/hw/memtrack.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-at.so”,target-name=”/system/vendor/lib64/libqti-at.so”,host-name=”/system/vendor/lib64/libqti-at.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-gt.so”,target-name=”/system/vendor/lib64/libqti-gt.so”,host-name=”/system/vendor/lib64/libqti-gt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libxml2.so”,target-name=”/system/lib64/libxml2.so”,host-name=”/system/lib64/libxml2.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libqti-perfd-client.so”,target-name=”/system/vendor/lib64/libqti-perfd-client.so”,host-name=”/system/vendor/lib64/libqti-perfd-client.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmedia_jni.so”,target-name=”/system/lib64/libmedia_jni.so”,host-name=”/system/lib64/libmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmtp.so”,target-name=”/system/lib64/libmtp.so”,host-name=”/system/lib64/libmtp.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjhead.so”,target-name=”/system/lib64/libjhead.so”,host-name=”/system/lib64/libjhead.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libexif.so”,target-name=”/system/lib64/libexif.so”,host-name=”/system/lib64/libexif.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libstagefright_amrnb_common.so”,target-name=”/system/lib64/libstagefright_amrnb_common.so”,host-name=”/system/lib64/libstagefright_amrnb_common.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libextmedia_jni.so”,target-name=”/system/lib64/libextmedia_jni.so”,host-name=”/system/lib64/libextmedia_jni.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,target-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,host-name=”/data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjavacrypto.so”,target-name=”/system/lib64/libjavacrypto.so”,host-name=”/system/lib64/libjavacrypto.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore-engine.so”,target-name=”/system/lib64/libkeystore-engine.so”,host-name=”/system/lib64/libkeystore-engine.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeystore_binder.so”,target-name=”/system/lib64/libkeystore_binder.so”,host-name=”/system/lib64/libkeystore_binder.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libsoftkeymasterdevice.so”,target-name=”/system/lib64/libsoftkeymasterdevice.so”,host-name=”/system/lib64/libsoftkeymasterdevice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster_messages.so”,target-name=”/system/lib64/libkeymaster_messages.so”,host-name=”/system/lib64/libkeymaster_messages.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libkeymaster1.so”,target-name=”/system/lib64/libkeymaster1.so”,host-name=”/system/lib64/libkeymaster1.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libEGL_adreno.so”,target-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,host-name=”/system/vendor/lib64/egl/libEGL_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libadreno_utils.so”,target-name=”/system/vendor/lib64/libadreno_utils.so”,host-name=”/system/vendor/lib64/libadreno_utils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libgsl.so”,target-name=”/system/vendor/lib64/libgsl.so”,host-name=”/system/vendor/lib64/libgsl.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv2_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/libllvm-glnext.so”,target-name=”/system/vendor/lib64/libllvm-glnext.so”,host-name=”/system/vendor/lib64/libllvm-glnext.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,target-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,host-name=”/system/vendor/lib64/egl/libGLESv1_CM_adreno.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,target-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,host-name=”/system/vendor/lib64/egl/eglSubDriverAndroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/hw/gralloc.msm8996.so”,target-name=”/system/lib64/hw/gralloc.msm8996.so”,host-name=”/system/lib64/hw/gralloc.msm8996.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libmemalloc.so”,target-name=”/system/lib64/libmemalloc.so”,host-name=”/system/lib64/libmemalloc.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdMetaData.so”,target-name=”/system/lib64/libqdMetaData.so”,host-name=”/system/lib64/libqdMetaData.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqdutils.so”,target-name=”/system/lib64/libqdutils.so”,host-name=”/system/lib64/libqdutils.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libqservice.so”,target-name=”/system/lib64/libqservice.so”,host-name=”/system/lib64/libqservice.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libandroid.so”,target-name=”/system/lib64/libandroid.so”,host-name=”/system/lib64/libandroid.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libcompiler_rt.so”,target-name=”/system/lib64/libcompiler_rt.so”,host-name=”/system/lib64/libcompiler_rt.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libjnigraphics.so”,target-name=”/system/lib64/libjnigraphics.so”,host-name=”/system/lib64/libjnigraphics.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/system/lib64/libwebviewchromium_loader.so”,target-name=”/system/lib64/libwebviewchromium_loader.so”,host-name=”/system/lib64/libwebviewchromium_loader.so”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.visualgdb.example.gdb_test1-1/oat/arm64/base.odex”,target-name=”/data/app/com.visualgdb.example.gdb_test1-1/oat/arm64/base.odex”,host-name=”/data/app/com.visualgdb.example.gdb_test1-1/oat/arm64/base.odex”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”/data/app/com.visualgdb.example.gdb_test1-1/lib/arm64/libgdb_test1.so”,target-name=”/data/app/com.visualgdb.example.gdb_test1-1/lib/arm64/libgdb_test1.so”,host-name=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\obj\\local\\arm64-v8a\\libgdb_test1.so”,symbols-loaded=”0″,thread-group=”i1″
&”warning: Could not load shared library symbols for 131 libraries, e.g. /system/vendor/lib64/libNimsWrap.so.\nUse the \”info sharedlibrary\” command to see the complete listing.\nDo you need \”set solib-search-path\” or \”set sysroot\”?”
&”\n”
*stopped,frame={addr=”0x0000007f7bc9b374″,func=”__epoll_pwait”,args=[],from=”C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so”},thread-id=”1″,stopped-threads=”all”,core=”2″
^connected
-break-list
^done,BreakpointTable={nr_rows=”0″,nr_cols=”6″,hdr=[{width=”7″,alignment=”-1″,col_name=”number”,colhdr=”Num”},{width=”14″,alignment=”-1″,col_name=”type”,colhdr=”Type”},{width=”4″,alignment=”-1″,col_name=”disp”,colhdr=”Disp”},{width=”3″,alignment=”-1″,col_name=”enabled”,colhdr=”Enb”},{width=”10″,alignment=”-1″,col_name=”addr”,colhdr=”Address”},{width=”40″,alignment=”2″,col_name=”what”,colhdr=”What”}],body=[]}
info shared
&”info shared\n”
~”From                To                  Syms Read   Shared Object Library\n”
~”0x0000007f7c0e1c80  0x0000007f7c105db8  Yes         C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\linker64\n”
~”                                        No          /system/vendor/lib64/libNimsWrap.so\n”
~”                                        No          /system/lib64/libcutils.so\n”
~”                                        No          /system/lib64/libutils.so\n”
~”                                        No          /system/lib64/liblog.so\n”
~”                                        No          /system/lib64/libbinder.so\n”
~”                                        No          /system/lib64/libandroid_runtime.so\n”
~”                                        No          /system/lib64/libwilhelm.so\n”
~”                                        No          /system/lib64/libc++.so\n”
~”0x0000007f7bc4c340  0x0000007f7bccd25c  Yes         C:\\Users\\zl121\\AppData\\Local\\VisualGDB\\AndroidBinaryCache\\9416189d\\libc.so\n”
~”                                        No          /system/lib64/libm.so\n”
~”                                        No          /system/lib64/libbacktrace.so\n”
~”                                        No          /system/lib64/libmemtrack.so\n”
~”                                        No          /system/lib64/libandroidfw.so\n”
~”                                        No          /system/lib64/libexpat.so\n”
~”                                        No          /system/lib64/libnativehelper.so\n”
~”                                        No          /system/lib64/libnetutils.so\n”
~”                                        No          /system/lib64/libui.so\n”
~”                                        No          /system/lib64/libgui.so\n”
~”                                        No          /system/lib64/libinput.so\n”
~”                                        No          /system/lib64/libinputflinger.so\n”
~”                                        No          /system/lib64/libcamera_client.so\n”
~”                                        No          /system/lib64/libcamera_metadata.so\n”
~”                                        No          /system/lib64/libskia.so\n”
~”                                        No          /system/lib64/libsqlite.so\n”
~”                                        No          /system/lib64/libEGL.so\n”
~”                                        No          /system/lib64/libGLESv1_CM.so\n”
~”                                        No          /system/lib64/libGLESv2.so\n”
~”                                        No          /system/lib64/libETC1.so\n”
~”                                        No          /system/lib64/libhardware.so\n”
~”                                        No          /system/lib64/libhardware_legacy.so\n”
~”                                        No          /system/lib64/libselinux.so\n”
~”                                        No          /system/lib64/libsonivox.so\n”
~”                                        No          /system/lib64/libcrypto.so\n”
~”                                        No          /system/lib64/libssl.so\n”
~”                                        No          /system/lib64/libicuuc.so\n”
~”                                        No          /system/lib64/libicui18n.so\n”
~”                                        No          /system/lib64/libmedia.so\n”
~”                                        No          /system/lib64/libjpeg.so\n”
~”                                        No          /system/lib64/libusbhost.so\n”
~”                                        No          /system/lib64/libharfbuzz_ng.so\n”
~”                                        No          /system/lib64/libz.so\n”
~”                                        No          /system/lib64/libaudioutils.so\n”
~”                                        No          /system/lib64/libpdfium.so\n”
~”                                        No          /system/lib64/libimg_utils.so\n”
~”                                        No          /system/lib64/libnetd_client.so\n”
~”                                        No          /system/lib64/libradio.so\n”
~”                                        No          /system/lib64/libsoundtrigger.so\n”
~”                                        No          /system/lib64/libminikin.so\n”
~”                                        No          /system/lib64/libprocessgroup.so\n”
~”                                        No          /system/lib64/libnativebridge.so\n”
~”                                        No          /system/lib64/libradio_metadata.so\n”
~”                                        No          /system/lib64/libhwui.so\n”
~”                                        No          /system/lib64/libstagefright.so\n”
~”                                        No          /system/lib64/libstagefright_foundation.so\n”
~”                                        No          /system/lib64/libstagefright_http_support.so\n”
~”                                        No          /system/lib64/libeffects.so\n”
~”                                        No          /system/lib64/libbase.so\n”
~”                                        No          /system/lib64/libunwind.so\n”
~”                                        No          /system/lib64/libstdc++.so\n”
~”                                        No          /system/lib64/libsync.so\n”
~”                                        No          /system/lib64/libpng.so\n”
~”                                        No          /system/lib64/libft2.so\n”
~”                                        No          /system/vendor/lib64/libqc-opt.so\n”
~”                                        No          /system/lib64/libGLES_trace.so\n”
~”                                        No          /system/lib64/libwpa_client.so\n”
~”                                        No          /system/lib64/libpcre.so\n”
~”                                        No          /system/lib64/libnbaio.so\n”
~”                                        No          /system/lib64/libspeexresampler.so\n”
~”                                        No          /system/lib64/libRS.so\n”
~”                                        No          /system/lib64/libRScpp.so\n”
~”                                        No          /system/lib64/libdrmframework.so\n”
~”                                        No          /system/lib64/libmediautils.so\n”
~”                                        No          /system/lib64/libopus.so\n”
~”                                        No          /system/lib64/libstagefright_omx.so\n”
~”                                        No          /system/lib64/libstagefright_yuv.so\n”
~”                                        No          /system/lib64/libvorbisidec.so\n”
~”                                        No          /system/lib64/libpowermanager.so\n”
~”                                        No          /system/lib64/libstagefright_enc_common.so\n”
~”                                        No          /system/lib64/libstagefright_avc_common.so\n”
~”                                        No          /system/lib64/libprotobuf-cpp-lite.so\n”
~”                                        No          /system/lib64/libcommon_time_client.so\n”
~”                                        No          /system/lib64/libbcc.so\n”
~”                                        No          /system/lib64/libbcinfo.so\n”
~”                                        No          /system/lib64/libLLVM.so\n”
~”                                        No          [vdso]\n”
~”                                        No          /system/vendor/lib64/libcneconn.so\n”
~”                                        No          /system/vendor/lib64/libvendorconn.so\n”
~”                                        No          /system/vendor/lib64/libavenhancements.so\n”
~”                                        No          /system/lib64/libstagefright_httplive.so\n”
~”                                        No          /system/lib64/libmediaplayerservice.so\n”
~”                                        No          /system/lib64/libstagefright_wfd.so\n”
~”                                        No          /system/lib64/libcurl.so\n”
~”                                        No          /system/vendor/lib64/libExtendedExtractor.so\n”
~”                                        No          /system/lib64/libdashplayer.so\n”
~”                                        No          /system/lib64/libart.so\n”
~”                                        No          /system/lib64/libsigchain.so\n”
~”                                        No          /system/lib64/libjavacore.so\n”
~”                                        No          /system/lib64/hw/memtrack.msm8996.so\n”
~”                                        No          /system/vendor/lib64/libqti-at.so\n”
~”                                        No          /system/vendor/lib64/libqti-gt.so\n”
~”                                        No          /system/lib64/libxml2.so\n”
~”                                        No          /system/vendor/lib64/libqti-perfd-client.so\n”
~”                                        No          /system/lib64/libmedia_jni.so\n”
~”                                        No          /system/lib64/libmtp.so\n”
~”                                        No          /system/lib64/libjhead.so\n”
~”                                        No          /system/lib64/libexif.so\n”
~”                                        No          /system/lib64/libstagefright_amrnb_common.so\n”
~”                                        No          /system/lib64/libextmedia_jni.so\n”
~”                                        No          /data/dalvik-cache/arm64/system@framework@tcmclient.jar@classes.dex\n”
~”                                        No          /system/lib64/libjavacrypto.so\n”
~”                                        No          /system/lib64/libkeystore-engine.so\n”
~”                                        No          /system/lib64/libkeystore_binder.so\n”
~”                                        No          /system/lib64/libsoftkeymasterdevice.so\n”
~”                                        No          /system/lib64/libkeymaster_messages.so\n”
~”                                        No          /system/lib64/libkeymaster1.so\n”
~”                                        No          /system/vendor/lib64/egl/libEGL_adreno.so\n”
~”                                        No          /system/vendor/lib64/libadreno_utils.so\n”
~”                                        No          /system/vendor/lib64/libgsl.so\n”
~”                                        No          /system/vendor/lib64/egl/libGLESv2_adreno.so\n”
~”                                        No          /system/vendor/lib64/libllvm-glnext.so\n”
~”                                        No          /system/vendor/lib64/egl/libGLESv1_CM_adreno.so\n”
~”                                        No          /system/vendor/lib64/egl/eglSubDriverAndroid.so\n”
~”                                        No          /system/lib64/hw/gralloc.msm8996.so\n”
~”                                        No          /system/lib64/libmemalloc.so\n”
~”                                        No          /system/lib64/libqdMetaData.so\n”
~”                                        No          /system/lib64/libqdutils.so\n”
~”                                        No          /system/lib64/libqservice.so\n”
~”                                        No          /system/lib64/libandroid.so\n”
~”                                        No          /system/lib64/libcompiler_rt.so\n”
~”                                        No          /system/lib64/libjnigraphics.so\n”
~”                                        No          /system/lib64/libwebviewchromium_loader.so\n”
~”                                        No          /data/app/com.visualgdb.example.gdb_test1-1/oat/arm64/base.odex\n”
~”0x0000007f772205a0  0x0000007f77220698  Yes         C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\obj\\local\\arm64-v8a\\libgdb_test1.so\n”
^done
-break-insert -f C:\Zhong\workspace\gdb_test1\gdb_test1\jni\gdb_test1.c:30
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0000007f7722060c”,func=”Java_com_visualgdb_example_gdb_1test1_gdb_1test1_stringFromJNI”,file=”jni/gdb_test1.c”,fullname=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\jni\\gdb_test1.c”,line=”30″,thread-groups=[“i1″],times=”0″,original-location=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\jni\\gdb_test1.c:30″}
-break-info 1
^done,BreakpointTable={nr_rows=”1″,nr_cols=”6″,hdr=[{width=”7″,alignment=”-1″,col_name=”number”,colhdr=”Num”},{width=”14″,alignment=”-1″,col_name=”type”,colhdr=”Type”},{width=”4″,alignment=”-1″,col_name=”disp”,colhdr=”Disp”},{width=”3″,alignment=”-1″,col_name=”enabled”,colhdr=”Enb”},{width=”18″,alignment=”-1″,col_name=”addr”,colhdr=”Address”},{width=”40″,alignment=”2″,col_name=”what”,colhdr=”What”}],body=[bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0000007f7722060c”,func=”Java_com_visualgdb_example_gdb_1test1_gdb_1test1_stringFromJNI”,file=”jni/gdb_test1.c”,fullname=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\jni\\gdb_test1.c”,line=”30″,thread-groups=[“i1″],times=”0″,original-location=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\jni\\gdb_test1.c:30″}]}
-break-after 1 0
^done
info symbol 0x7f7722060c
&”info symbol 0x7f7722060c\n”
~”Java_com_visualgdb_example_gdb_1test1_gdb_1test1_stringFromJNI + 48 in section .text of C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\obj\\local\\arm64-v8a\\libgdb_test1.so\n”
^done
info line *0x7f7722060c
&”info line *0x7f7722060c\n”
~”Line 30 of \”jni/gdb_test1.c\” starts at address 0x7f7722060c <Java_com_visualgdb_example_gdb_1test1_gdb_1test1_stringFromJNI+48> and ends at 0x7f7722063c <Java_com_visualgdb_example_gdb_1test1_gdb_1test1_stringFromJNI+96>.\n”
^done
-file-list-exec-source-files
^done,files=[{file=”jni/gdb_test1.c”,fullname=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1\\jni\\gdb_test1.c”},{file=”<built-in>”,fullname=”C:\\Zhong\\workspace\\gdb_test1\\gdb_test1/<built-in>”},{file=”C:/Android/android-ndk-r10e/platforms/android-21/arch-arm64/usr/include/jni.h”,fullname=”C:\\Android\\android-ndk-r10e\\platforms\\android-21\\arch-arm64\\usr\\include\\jni.h”},{file=”c:\\android\\android-ndk-r10e\\toolchains\\aarch64-linux-android-4.9\\prebuilt\\windows\\lib\\gcc\\aarch64-linux-android\\4.9\\include/stdarg.h”,fullname=”c:\\android\\android-ndk-r10e\\toolchains\\aarch64-linux-android-4.9\\prebuilt\\windows\\lib\\gcc\\aarch64-linux-android\\4.9\\include\\stdarg.h”}]
-exec-continue
^running
*running,thread-id=”all”
***************** content of Application.mk     ****************************
APP_ABI := armeabi armeabi-v7a arm64-v8a
can found obj/local/arm64-v8a obj/local/armeabi   obj/local/armeabi-v7a
****************** GDB launch output **************
Found 0 .natvis files in the current project
VisualGDB: Executing predebug actions
Launching Android project…
Using settings from a VisualGDB project settings file C:\Zhong\workspace\gdb_test1\gdb_test1\gdb_test1-Debug.vgdbsettings…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe devices
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.release
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ps
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell id
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d install -r “C:\Zhong\workspace\gdb_test1\gdb_test1\bin\gdb_test1-debug.apk”
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.visualgdb.example.gdb_test1 /system/bin/sh -c pwd
Using app directory: /data/data/com.visualgdb.example.gdb_test1
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.product.cpu.abi
Detected device EABI: arm64-v8a
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell getprop ro.build.version.sdk
Detecting linker breakpoint workaround for toolchain 23 on 9416189d…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/data/com.visualgdb.example.gdb_test1/lib
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell pm list packages -f
APK file path on device: /data/app/com.visualgdb.example.gdb_test1-1/base.apk
Normal library directory: /data/app/com.visualgdb.example.gdb_test1-1/lib/arm64-v8a
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.visualgdb.example.gdb_test1-1/lib/arm64-v8a
Normal library directory contains no .so files. Searching for replacements…
Checking /data/app/com.visualgdb.example.gdb_test1-1/lib/arm64…
Found .so files. Using /data/data/com.visualgdb.example.gdb_test1/lib as the new library directory
Checking Android project ABI…
Device ABI: arm64-v8a
Library directory: C:\Zhong\workspace\gdb_test1\gdb_test1\libs
Checking for C:\Zhong\workspace\gdb_test1\gdb_test1\libs\arm64-v8a\gdbserver…
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d pull “/data/app/com.visualgdb.example.gdb_test1-1/lib/arm64/libgdb_test1.so” “C:\Users\zl121\AppData\Local\Temp\tmpC58A.tmp”
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell am start -n com.visualgdb.example.gdb_test1/.gdb_test1
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell ls /data/app/com.visualgdb.example.gdb_test1-1/lib/arm64/gdbserver
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d shell run-as com.visualgdb.example.gdb_test1 /data/app/com.visualgdb.example.gdb_test1-1/lib/arm64/gdbserver localhost:5039 –attach 3735
VisualGDB: C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe -s 9416189d forward tcp:5039 tcp:5039
Looking up GDB…
GDB reported by ndk-build: C:/Android/android-ndk-r10e/toolchains/aarch64-linux-android-4.9/prebuilt/windows/bin/aarch64-linux-android-gdb.exe
Found toolchain: C:\Android\android-ndk-r10e\toolchains\aarch64-linux-android-4.9
Found GDB: C:\Android\android-ndk-r10e\toolchains\aarch64-linux-android-4.9\prebuilt\windows\bin\aarch64-linux-android-gdb.exe
Creating pending breakpoint…
VisualGDB: Executing stop actions
VisualGDB: Executing postdebug actions
